Originally Posted by 76Beeper
Originally Posted by DAYCLONA
Here you go Lou... Auto top/4spd bottom, .....if need be you can convert the auto crossmember to 4 speed use with a little surgery if that's the case?
mike
Mike,
Can you show the auto and 4speed cross members for a 1971 B-body?
Thanks.
Sorry no pics, but IIRC the 71-2 B body uses the same crossmember auto or 4spd, much like the 70-4 E body does
Mike
