A couple of years ago after my car had been down for a while I got it running again. I was using a set of 14.5 x 33 M/T Drag Radials that were well over ten years old.
Everything was fine for a while then the car started making violent right turns immediately off the starting line.
I worked with Calvert and a local chassis guy with no improvement.
I changed to set of equally old bias ply Goodyears and the car returned to going straight.
I then replaced both sets of tires.
I will say the M/Ts looked great, no weather cracking or discoloration and the wear indicators showed little wear.
A little different but I know that Discount Tire will not mount a tire that is over ten years old.
