Guys,
Replacing bearings on a stock open diff 8-3/4 rear axle, the FSM says to adjust all bearing end-play on the passenger side, cuz there is no adjuster on the driver's side...
So if you tighten the end-play adjuster on the passenger side down until you have no end play on the passenger side - but STILL have end play on the driver's side - do I recall correctly that we have to add shims or something on the driver's side? Or what do you do to tighten the end play on the drivers' side when you have nothing left to adjust with on the passengers side?
Thanks,
- Art
65 Satellite hardtop 361/4bbl console 727 2.76
67 Satellite convert 383/2bbl column 727 3.23
67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd
67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd
71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd
82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle
75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF
77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF
07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
