If things work out to the good maybe I'll be able to take you up on finally seeing racers run at Bonneville up luck
El Mirage dry lake racing was a lot different looking than the salt at Wendover up
Work on slicking that body up, reduce the wind friction up wrench grin
Good Luck up
