Originally Posted by RWG75
Originally Posted by Grizzly
Let go, Man, just let go.
I just installed Fram number 4 hundred and something on one of the personal vehicles with over 100,000 miles on it and zero issues. 319,000 miles on the money-maker with an "orange can of death" and it's still...........making Me money.
Have not "bulged a canister", or "lost oil pressure", or turned a muffler bearing yet.
On a side note, I calculated I've saved $10,210.00 by doing my own oil changes, running Fram filters and buying Exxon Mobil in bulk. twocents twocents twocents twocents wink
On ANOTHER side note, has anyone seen what a Fram CA332 goes for these days? whistling
Ya know, I've never understood the Fram bashing. Ya can't swing a dead cat on the internet without hitting a thread about slicing up oil filters and being told that Fram is crap. I've been running them since the 80s with exactly one problem. Some how I got one that slipped past QC with no threads in the base plate.
There is a reason why you see all the Fram bashing, it's because they are nothing more than adequate at best and garbage at the worst. Maybe you will never have a problem with one, but maybe you could have a catastrophic failure with one too. There are better quality filters readily available for a few cents more. Why would you want to gamble, especially with an expensive race engine?
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
