how does that work ?
my tv is a samsung, but i don't know how "smart" it is. [anything these days is smarter than i am.
It's for 2016 and newer Samsung TV's, there should be a port in the back of the TV to connect an internet connection, which you will need or you can set it up wirelessly. In my case wired is a much better setup. You will probably need to go to settings as well and setup your network.
When your TV is on hit the home button (looks like a house) and you should see "TV PLUS" at the bottom, you may need to arrow left to see it.
