4640 is a 750cfm Carb - 440 HP
Nothing wrong with that carb especially if it’s in good shape and you want to install the flat metering rod covers , and then convert to the Edelbrock metering rods/jets
That way you can test and tune the easy way
Watch for the hot idle compensator and vacuum , I like to block them off with my own gasket
Also float level and drop is critical
And the accelerator pump leather drying out
I can’t remember what Edelbrock accelerator pump I ended up using / WAS NOT the Blue one
Flat Metering Rod Covers
Edelbrock
.101 Primary Jets - .065X.052 Metering Rods
.107 Secondary Jets makes for a good start
