OMG!! I'm having hard flashbacks right now! The Club Cab I owned back in the '90's was this same exact color (mine was a 1/2 ton though). I got rid of mine because the frame was coming apart I guess due to the high miles it had (300K+?). Mine had no real rust, but had numerous little dings and was lightly sideswiped down the passenger side of the bed. Mine originally had 360/727 and I swapped in a (stock) 440/727 from a '77 cop car. When I did the big block swap, I also swapped out the stock tank for a 36 gallon Ramcharger tank. Being that I did all this in the '90's, parts (and parts trucks) could still be found pretty easy and fairly cheaply.
*sigh*
