There needs to be no back pressure in the return line. It should be the same size as the feed line or preferably one size bigger. No tight bends or pinched line. The return line should exit close to the bottom of tank below fuel level to prevent aeration and away from the pickup.
In theory, there is no difference between theory and practice. In practice, there is.
