They come both ways.
Most are 4 groove.
Just get the correct locks and you’re good to go.
If the seats haven’t been cut for that size valve, there isn’t going to be really any benefit to using them, and it will likely create a spring installed height and/or a valve tip height problem.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123
Dealer for Comp Cams/Indy Heads
