Originally Posted by Frankie P
Can someone tell me why the Year One date coded ignition wires cannot be used with electronic ignition?
Frank
These ?
https://www.lectriclimited.com/spark-plug-wire-set-215377
If so , what I can tell you is that they are CARBON CORE wires - Not that there is anything wrong with that , however I can state for a fact they are very very high ohm resistance
I had been running a set on my 383/432 Stroker for a few years now - They look great and even fit better then expected , but when it came to inconsistent RPM’s , especially higher , I was chasing my ass between ignition coils and ECU s , even fuel pressure , just couldn’t put my finger on it because it was so inconsistent
So this past month after getting my car out of storage , the first few drives on the street I just wasn’t happy
Pulled the plugs , wires , and compression test AGAIN , just looking everything over while I had time on my side
I couldn’t believe the ohm resistance on these wires when I tested them used , and even against another new set that I have here in the bag
The longest wire #7 was in excess of 20,000 Ohms brand new
OK
So last month I put on a new set of Pertronix 7mm SPIRAL CORE wires set up for a big block
I wanted to use the factory spark plug wire holders
The longest wire #7 had less then 2,000 Ohms
Beyond happy with the fit (A little long on some) , looks and PERFORMANCE difference - Night and day honestly
Picture is my old set up last year with those date coded wires
Now running a Pertronix coil that I installed last year chasing my ass , ballast resistor is bypassed on the back side - Pertronix 7mm Spark Plug wires - Same distributor - Same Mopar Chrome ECU that I have had like forever
Only thing that I changed this spring was those plug wires - Difference maker
383/432 Stroker - 75cc E Street Heads - XE275HL - Chrysler / Pertronix Ignition - 800 AVS 2
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
