[quote=PhillyRag]
Seems to be that to determine IF a shop does "good" body, Check out what/how much "bondo" they have in-house.
If gallon cans >>>>> Run Forest Run.
The west coast "technique" for decades has to been cover the entire vehicle in bondo even if it's not needed, and carve it to shape, personally I'd rather spend some hammer/dolly time to straighten panels, along with time spent to align/tweak panels as well, then block several coats of high build primer to "straighten" the body, but for the majority, time and money is their concern, so bondo, putty/fillers/creams/etc are their short cut to "perfection" to hide hack work...that's a shame when you try to make a name in the hobby, I see it in almost all the "big name" shops/restorers, some more than others
