The C Body article is great. More info, there is a Dorman kit that provides new plastic "pucks" instead of the nuts mentioned.
They can be difficult to install. A trick is to freeze the center metal gear and pucks, and heat (moderately, like a 300 degree oven) the outer ring, then the parts will fit together much easier.
Mark
