Get the car on stands then disconnect shifter rod/cable from lever on trans. Moved kever all the way back while turning the driveshaft.
If the driveshaft locks then the park rod is in the right spot. Place your shifter in park and adjust the length if needed for the shift rod to engage that lever.
Now try it.
