Originally Posted by radar
the crazy thing is that the old gear was reeaaly close to correct if bot dead on, and when I pulled it it’s a 54!
At some point in time, newer gears no longer had the tooth count embossed in them, they went to the last two digits of the part number.
If you count the teeth on it, there are not 54.
