Re: Starting on my 79 W150, could use some advice, ideas, help
[Re: poorboy]
#2762579
04/11/20 07:47 AM
04/11/20 07:47 AM
Posts: 5,914 ohio
ruderunner
ohio
The ignition wire that would normally go to the + side of the coil on your Dodge now needs to go to the + terminal on your GM electronic ignition. If you have a tach, there should be a connection place on the GM dist to connect your tach lead that normally would have connected to the + coil wire on the Dodge stuff.
Can't help you on that GM 1 wire alt. They call it a 1 wire, but most I've seen have 2 wires, so I'm confused. LOL! Gene Poorboy is close on the distributor. The HEI system needs full voltage not the lower coil voltage of the Mopar system. Take the power from the keyed side of the ballast resistor. As for the alternator, iirc the second small wire is for a warning light. Not needed for the alternator to function. But you do have to bring the rpms up to activate the internal regulator. Honestly id keep the stock charging system because of the tricks you can do in case of roadside failure of the regulator or wiring.
Angry white pureblood male
Entire Thread
furious
03/31/18 02:17 PM
Guitar Jones
03/31/18 05:11 PM
furious
03/31/18 07:00 PM
QuickDodge
04/01/18 03:52 PM
furious
04/01/18 04:22 PM
ric3xrt
04/01/18 04:30 PM
NV69B7RR
04/01/18 04:33 PM
ruderunner
04/01/18 05:08 PM
furious
04/01/18 07:01 PM
ruderunner
04/01/18 09:44 PM
Mr onetwo
04/02/18 08:44 AM
Morty426
04/02/18 11:55 AM
bbtrux
04/02/18 02:14 PM
furious
04/06/18 12:51 PM
jerseybud
04/06/18 01:39 PM
furious
04/06/18 02:21 PM
jerseybud
04/07/18 12:51 AM
furious
04/07/18 01:43 AM
larrymopar360
04/07/18 08:48 PM
440_Offroader
04/08/18 12:03 AM
ruderunner
04/07/18 01:34 PM
Mr onetwo
04/07/18 02:18 PM
4x4 Roundup
04/07/18 11:50 PM
buildanother
04/08/18 12:56 AM
furious
04/08/18 01:30 AM
buildanother
04/08/18 01:58 AM
furious
04/08/18 01:26 AM
4x4 Roundup
04/08/18 02:15 AM
larrymopar360
04/08/18 07:20 PM
demon
04/08/18 02:40 AM
furious
04/08/18 03:24 AM
4x4 Roundup
04/08/18 04:23 AM
furious
04/08/18 05:16 AM
Mr onetwo
04/11/18 12:03 PM
geo.
04/12/18 01:29 AM
furious
04/13/18 04:10 AM
AdventurerSport
05/03/18 09:43 PM
furious
05/04/18 12:44 PM
furious
04/15/18 02:52 AM
buildanother
04/15/18 03:07 AM
furious
04/15/18 03:32 AM
4x4 Roundup
04/18/18 03:33 AM
larrymopar360
04/15/18 08:11 PM
furious
04/16/18 01:50 AM
ric3xrt
04/18/18 12:31 PM
furious
04/21/18 01:04 PM
larrymopar360
04/28/18 05:09 AM
furious
05/03/18 07:57 PM
larrymopar360
05/05/18 09:50 PM
furious
05/06/18 03:43 PM
furious
05/07/18 01:23 AM
larrymopar360
05/07/18 02:25 AM
furious
05/13/18 09:12 PM
larrymopar360
05/15/18 10:56 PM
NV69B7RR
05/18/18 05:06 AM
furious
06/01/18 02:34 PM
ric3xrt
06/02/18 01:25 PM
furious
06/02/18 03:34 PM
4x4 Roundup
06/14/18 02:49 AM
furious
06/16/18 02:46 AM
furious
08/16/18 01:43 AM
larrymopar360
08/17/18 11:32 PM
furious
08/18/18 04:29 AM
furious
04/11/20 01:00 AM
furious
04/11/20 01:15 AM
poorboy
04/11/20 01:48 AM
ruderunner
04/11/20 11:47 AM
larrymopar360
04/11/20 05:48 PM
furious
05/02/20 12:44 AM
buildanother
05/02/20 02:14 AM
furious
04/11/20 08:49 PM
redraptor
04/11/20 11:23 AM
furious
05/02/20 12:20 AM
