Originally Posted by polyspheric
I would expect a color change and spalling.
iagree
The damage done depends on how long it was run with the bearings stacked one over or under the other one, if you run them long enough that way they will usually break a rod bolt and then the rod cap unwinds and breaks the rod and block puke
Seen more than one BB Chevy have that happen at the drags in SO CA whiney
