Originally Posted by cb1289
If you have the directions that came with the pump, read them carefully. The aluminum castings can crack easily if you use Teflon tape when installing your fittings to the pump body. Teflon tape is a no no. Seal them another way and don't overtighten.
Thanks! No instructions in the box.... what do you use in place of teflon tape?
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
