Poor old Randy / Labratt is gone, folks - check the date on the posting - still, I KNOW the piece he was looking to get done and I got bent over by at least 1 plater, badly. They ended up destroying the part in the acid tank. Pot metal plating is the toughest job because the metal is basically junk. The repops may be a better bet, rather than trying your luck with a plater, and a piece that large...
