Total Seal says .0045 per inch of bore for gas, alky , e85. Doug it sounds like a bigger gap isn't hurting your performance at all with the gets you run. Which brings?me to the statement on the box; if you have had good luck with another gap size than recomended, go with the bigger of the two. Lots of variables can affect the minimum gap required.
