Generally speaking raising spring rate on an accumulator spring firms the shift for some shifts.
It also builds clutch capacity for the system.
When the spring is energized you have done work, when the spring relaxes when the acc. piston stroke strokes it adds that fluid pressure to the system, depending on valve body and case design.
