Yes power brakes and power disc available. Dana for 4 speed, but that was not hemi specific as 440 had them also. Hemi Emblems, believe torque boxes, and hemi type k-frame mounts. Vin for sure.
All 1967 B-Body power disc brakes used the offset "Hemi" booster. If you got the Hemi with the Torqueflite, you got manual drum brakes and an 8 3/4. If you went with the 4-sp, power front discs and the Dana were mandatory options. As to Hemi only, yes, torque boxes and the Hemi K-frame were necessary. 3/8" fuel lines rather than 5/16". The item most overlooked in a clone or an imposter is the plate welded to the rear floor pan that the pinion snubber contacts.
