Truthfully I'm in no hurry to start this build, I have four other new complete ready to run and use pump gas motors and three cars, two that need mtors
Sammy, I already had the crankshaft, rods, solid roller lifters and cam before ordering and paying half up front to lock this block deal in two years ago so that determined the C.I.. I need to get the used B1 heads done so I can check the CC and when I get the block deck height info on it I can order pistons for it to start the build. The rods are a new set of Carrillo aluminum top alcohol that I bought for this build due to the price, there a little different in length with a big wrist pin than I would normally use but do to having to have pistons made anyways I thought why not use what I can and see what pops out the other end
