15x7 reproduction Rallyes are fine if your putting them on a 72 and up car. The reproductions were based on the Canada made wheel which came into play in 1972 model year.
The oval holes have a larger shrouding that once you know about it your eye will notice.
Backspacing is the same as a Chrysler rim and you can even get custom backspacing.
See me attachments and study the oval holes.
***note the wheel with 72 center cap is reproduction but has a correct brushed ring, the wheel with 71 center cap is original and has a correct brushed ring****
Ron
