If it is a trans brake car with some electronics I would consider using the electronic box to turn on the NOS system based on time from release of the tranny button activation as well as wide open switch to turn it off when you go from WOT to less than WOT as a fail safe feature up scope
If no electronics in the car then a toggle switch with a push button and WOT switch to control it twocents
