Originally Posted by AndyF
That should be a really nice street cam. The hyd roller that I have in my Coronet is roughly the same size but on 112 lobe centers for even less overlap. For your application I'd say that cam is a pretty good choice.
This is great news. Andy, did you use the Comp lifters with the Coronet motor? If not, what do you suggest for this application? I called Hughes and they suggested using the Howards they sell. Thanks to all for the advice.
