I’m not so sure a flat top 400 even with closed chambers is 10 to 1. More like 8.5 to 1
It all depends on the deck height, gasket and chamber size. A .035" over 400 with zero deck height, a steel shim gasket and 75 cc heads would have a compression of 11.39.
