Originally Posted by fast68plymouth
I’d have measured the guides for clearance to see if they were worn out or not.
If they didn’t need replacing, I’d have run the heads through the jet wash and bead blasted the chambers and bowls to save the guides.
A couple of the guides had pretty good wobble when I broke them down , so they would need some attention regardless.
