Cleaning out parts and I came across these. I have 2 each left hand threaded studs of the sizes you see. These are the last 4 that I have. Will either of these work for you? The shorter ones are used but good. The longer ones are new. PM me Terry
Top one is rear Bottom one is front disc brake rotor
