10.2v is fine on cranking. I was working on a no-start situation on a '66 Barracuda recently. Due to a bad underhood harness I was dropping to 8v while cranking with a cheap Chinese distributor that won't fire at less than 10v. As stated above, ground on the ignition box is critical and one of the most overlooked problems.
