I've only got .6 acer of land here, I've got 2 side hills, one is 30' wide and the other is about 40 ' wide and both are about 100 feet long. A couple years ago I bought a 48" Husqvarna, it cut my mowing time down to about 20 minutes from what my old Craftsman 42" cut garden tractor did in about an hour and a half. I can tell you it really doesn't like those hill sides. If everything is dry, I can do the 40" wide part sideways, but the 30' wide I have go up and down the 30' width.
If you have never driven a zero turn, it takes some getting used to. The first few times it looked like a drunken sailor did the mowing. If you get in a hurry, it tends to tear up the lawn on quick zero turns. Gene
