Mostly electrical gremlins . ESPECIALLY grounds
Only the 3.0 single overhead cam motors had the valve guide issues as far as I know. which usually causes to smoke at idle and 1st pulling away from stops once warmed up
The 5 spds are well known for axle seal leaks and the trans doesn't hold much oil so it only takes a small leak and the trans is toast quick
