Thanks guys,I was thinking OBD 2 would be the choice for it but the OBD 1 is nice being a simple harness to fit in the truck.
As far as the intake I'd keep the kegger with the Hughes plate or weld a solid plate on the bottom. I've used the Hughes plate on prior Magnums,it's a thick chunk! Thanks again,RT.
