(Quote} When i rock the pistons like that they all seem to be the same but they do possibly stick up above the deck surface a hair. They are basically all at o when they are flat. They dont rock much in the hole. [/quote]
Your thinking is normal before you measure them, .003 to even as much as .010 is hard to see and feel. To get actual results between them you need to measure them with depth mike, maybe even a set of dial calipers if your real careful using them or a dial indicator on the edges.
I've learn to many stupid lessons on Hi Po motors by NOT making sure on measurements like these
Be safe and make sure your good before taking any chances
