You can often 'recover' a failing hard drive (temporarily) with Steve Gibson Research's Spin Rite software. I'd recomend running that on the drive, if it 'fixes' it, duplicate the drive to a new drive. Once they start to go bad, they won't live long even after fixed. https://www.grc.com/sr/spinrite.htm$0.02..... Ben Thanks I will give that a try. I have a SSD in another PC that already has Windows 10 on it. Is that useable? I've been trying to back this up to the cloud but not having any luck doing that.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost conversion. 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
