The New Venture 4500 was used in GM trucks. There are differences though. I know the input shaft is shorter and some may have different ratios. A google search on the NV 4500 will turn up quite a bit of information on them.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost conversion. 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
