Just use a normal timing curve. Maybe 15 at idle, 35 at WOT, 42 at cruise. Fill those blocks in and smooth the table. Are you using the handheld to enter numbers or have you hooked up a laptop? If you use the handheld you end up with a really blocky table. Best way is to hook up a laptop or pull the SD card and program it on your desktop computer.
Is 42 at cruise correct? Or a typo. Thanks
Not sure what your real question was. Do you think 42 is too high or too low? It is fairly common to run more than 42 at cruise but I suggested 42 as a starting point. With a Sniper you can drive down the freeway and adjust the timing to find out what it really wants. Your combination might want 45 or 47 or 50 degrees of total timing while cruising down the freeway. All depends on the engine and the car.
