Over the years, I have had upper ball joints that I have had to use 3/4" air impacts to twist in and have had some that wouldn't tighten up, only spin and spin. I'ld throw some lube on the threads, internal and external, and hit it with the impact. Worse that could happen is that you would have to replace them. But I bet it will go with enough persuasion.
Master, again and still
