I look at oil pressure from a different perspective... as long as the engine has 15 to 20 psi after the trip down the quarter mile I don't care what the max pressure is. I just look at the data after the run to see if the pressure matched the rpm going down the track to make sure there was no fall off. grin
If it ain't broke fix it anyway!
