This is where horsepower in da blue bottle really shines!
Yes, nitrous is one way to do the trick. In that case I'd use premium engine components so it will handle the extra power output. A high quality forged crank, high quality rods, high quality pistons, top shelf rings and bearings, excellent machine work, head studs, cometic gaskets, etc. Then you should be able to build a very mellow 600 hp street cruiser that easily runs 10's with a 100 or 150 hp shot. If you build the engine and the driveline to handle 750 hp then you should be good to go for a long time. That means a beefed up transmission, heavy duty driveshaft and a Dana 60 rearend.
