From what I can see..... they still make it, it’s just not a -3 price code anymore.
It’s a -5 now....... 20-418-5.
It’s ground from the “dual energy” lobes, which are pretty mild and made to be easy on parts.
Since a -5 is the same price as a custom....... I’d probably do something a little different for that $$$.
https://www.summitracing.com/parts/cca-20-418-5
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123
Dealer for Comp Cams/Indy Heads
