Originally Posted by Sniper
Same flexplate as an LA would use, assuming it's carbed. Make sure your torque converter has the Magnum imbalance weight on it.
LA and Magnum don't have the same amount of imbalance. Magnum flex plates are available to fit neutral balance converters. Just not sure if there is a part that fits the 904 trans.
Doug
