I was told by the vendor I use that it can be wet sanded and polished for maintenance/stain removal.I'm sure just a polishing compound for paint would work without sanding for maintenance. He also said the coating is dull when applied and is put in an abrasive tumbler to bring out the surface sheen. RT
