How you measured the valve lift would be helpful. If you measured it at the valve then what rocker arms it has would also be important as most rockers aren't exact, especially stock rockers. Also is this a hydraulic or mechanical cam? If it's a mechanical cam then what was the lash?
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost conversion.
2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
