I chased my tail all summer with charging problems, I thought I had it solved with a new alternator, Then it wouldn't start again at a gas station.
I finally found out that the engine wasn't grounded good enough. One ground strap from the engine to the frame solved all problems. I know you mentioned you checked your grounds but make sure the engine is grounded very well.
1970 Challenger, all aluminum 528 Hemi, HDK suspension, Tremec 5 speed manual
