So to be more clear, when you are assembling the rockers, looking down on them, starting on the left, it will be 1 without oil holes, then 1 with, then one without, then one with, then the oddball on the right. The shaft are different lengths but you will figure out which is which. Install the shafts with the banana groove down. Kinda like a jigsaw puzzle.
