Nothing but steam in mine. I ran it 41 passes and just drained it for the first time. A few drops of water/oil in it, maybe a tbsp. I think a lot of the large amounts of oil many see are from engine that are not sealed well or have poor oil control. FWIW I do not regulate any of mine.
Al, How do you run your rear main seal? I suspect mine pulls air there.
Doug
I am with Al, nothing but water, have 11 inches at idle, 17 downtrack, double lip seal on the rear main (fastfish), the timing chain cover seal has 2 springs and the backside was filled with RTV (cured) before being installed. If i had a Jesel belt drive it would seal better.
Joe
