Could just be factory tolerances. That spacing is going to depend on the thickness of the gasket behind the timing cover and the water pump. It also depends on how the water pump was built. If everything is assembled correctly then I'd use a shim behind the water pump pulley to line it up perfect.
http://arengineering.com/home-page/pulley-spacers/
