Originally Posted by geo.
I did this a long time ago, I think i separated it at the transmission end.
I hope someone who's done it recently will verify!
On my '76 with an NP203 i pulled the engine at the same time and left the transfer case chained up under the truck.
Your NP208 isn't as heavy so you might not need to do this!
I did the same on my '77 when the trans needed redone.Easier to pull it out of the front as those 203 cases are HEAVY! Plus no crossmember to mess with. RT
