Originally Posted by Cab_Burge
The AAR and T/A blocks, heads, rocker arms, pushrods, intake system are for those motors only, the rest of the internal parts like the rods, crank, pistons, lifter and camshaft and timing set, oil pan, timing cover, valve covers and so on are the same up
If you don't have the original block and want one I may know where one is work
PM me on here If so up
The Valve Covers are not the same.
